After testing the speed today, I found that the internet speed was less than 200mbps.Do you have similar problems? ![]()
ARM1000 speedtest measures less than 200mbps
Ronin -
18. November 2023 um 10:12 -
How did you test?
Speedtests to destinations within Europe show me between 600 and 1200 MBit/s. Do you test the speed with your home internet connection?
Don't order a budget machine in Germany and expect Gigabit in your home country.
CodeNode Name Upload Speed Download Speed Latency Speedtest.net 178.92 Mbps 188.47 Mbps 0.25 ms Montreal, CA 197.80 Mbps 193.74 Mbps 91.41 ms Paris, FR 197.32 Mbps 191.60 Mbps 21.92 ms Amsterdam, NL 197.46 Mbps 190.98 Mbps 10.72 ms Mumbai, IN 205.97 Mbps 195.36 Mbps 119.42 msI seem to understand. Is it related to my data usage exceeding 50TB?
Will ARM limit the use of high-speed traffic? Rate limiting after I use more than 50TB?
How did you test?
I'm running speedtest-cli on ARM 1000 for testing
As far as i know, there is a rate limit on all Netcup virtual Servers and that looks likely to be your problem.
On a VPS it is in effect after 80TB/month, on root-server(RS) after 120TB/month, don't know the details for the ARM servers.
I am curious, what is causing such high traffic?
Maybe you can buy a dedicated NIC for a monthly fee, but i don't know if that is possible.
WTF!?
WTF!?
download-Server or/and torrents
I think it's not the monthly limit but the fair use policy which cuts down the network speed after consuming an avarage MBit/s within an hour.
For the Rootservers this happens after 1 GBit/s, I think for the VPS (which the ARM should be) the value would be tendencially lower then 1 GBit/s. -
For the Rootservers this happens after 1 GBit/s, I think for the VPS (which the ARM should be) the value would be tendencially lower then 1 GBit/s.ARM 1000 seems to be the RS series, it should have more traffic, right?
ARM 1000 G11 Beta - 3 Monate kostenlos, danach 6,96 EUR / Monat (Laufzeit 12 Monate)
Prozessor: 6 vCores
Arbeitsspeicher: 8 GB RAM
Festplattenverbund: 256 GB NVMeARM 2000 G11 Beta - 3 Monate kostenlos, danach 12,00 EUR / Monat (Laufzeit 12 Monate)
Prozessor: 10 vCores
Arbeitsspeicher: 16 GB RAM
Festplattenverbund: 512 GB NVMNo officially you are getting vCores and that should be a sign vor VPS not vor RS Series at Netcup.
But instead of doing more and more guess work it maybe better if you are contacting the Netcup Support. They are the only ones that can give you the real reason for your system behaviour.
I see that the CCP product panel is labeled Root Server.
As mentioned before Netcup Support is the only way to know why your bandwidth ist cut down. But it should be caused by extensive use.
This is a community forum, were you can find a solution for nearly every technical question, but for this kind of contractual question Netcup support should be the better counterpart for you.
I have ARM 2000
Paying attention ~ I hope to see the reasons and results.
I have ARM 2000
I learned through the ticket: With the current beta servers, the limit is 40 TB per month.
Just to be sure: You know you're supposed to test the server itself, not the bandwidth?
netcup expects feedback on the functionality of the test server as well as suggestions for improvement based on your user experience.
If this is indeed the case, then I will have to cancel the server.
