HI All,
new here, and not yet read a lot here.
But got a urgent question about my (second) new server.
What network settings do I need ? DHCPv4 is not working and as far as I know I do not have all the settings for manual IPv4 setup.
Any clue?
network settings Ubuntu
no1san -
7. Januar 2025 um 17:56 -
All required Information is in the SCP, as well for IPv4 as for IPv6.
Nevertheless, DHCPv4 should work, even if not recommended.
im missing in SCP:
Subnet
nameserverssearch domains
Why is dhcp not working? (see screenprint in my first post)
Also my first server I accepted the default and is woking fine but don't know how.
pasted-from-clipboard.png -
The DHCPv4 setting as shown in the screenprint are not working.
That is a quirky configuration. The subnet is supposed to be in CIDR format, like the way your address is given in the server control panel. Basically the same as the address, but with the netmask length, like 192.168.0.1/24 if your address is 192.168.0.1 and your netmask is 24 bits. Actually you're supposed to clear the bits that identify the host in the subnet, but it should work if you just put the CIDR address there. The address is the same without the netmask. The gateway is given in the SCP. The nameservers aren't specified anywhere, but there is a topic in this forum. You can use any nameservers you like, for example 9.9.9.9 (Quad9), 1.1.1.1 (Cloudflare), 8.8.8.8 (Google), etc.. You can leave the search domain empty. That's a list of domain suffixes that the resolver should try adding to hostnames without a dot. This is rarely used.
In case of network trouble, the rescue system can be a reference for checking if the virtual machine is working correctly.
SCP IP = xxx.xx.xxx.0/22
well xxx.xx.xxx.0/22 is not working because of the bit set.
http://https//askubuntu.com…s-host-bits-set
Any idea how to fix 0/22 ? -
This gets you all the parameters from the address as given in the SCP:
http://https//mxtoolbox.com/SubnetCalculator.aspx
Enter just the address, select the netmask length from the dropdown menu and click 'calculate'.
(Canonical really needs to overhaul that configuration form. That's archaic.)
Please, make yourself familiar with basic knowledge about IP networking. And I mean really just the very basic knowledge.
How will you manage your server when it comes to Firewall and security settings? Be aware that your server is attacked once per second as soon as it has a public IP address. And there is no system firewall at Netcup, like other hosters do it. You have to configure everything on your own. Are you sure, you are able doing this?
So what do you prefer for subnet ?
SCP info IP = 1.1.1.0/22
should be in CIDR form (xx.xx.xx.xx/yy)
you can use:
https://mxtoolbox.com/subnetcalculator.aspx
please let me know. -
Oh no, by failing to guess the unusual network configuration format that the Ubuntu installer expects and not being able to do bitmask calculations in your head you have triggered the only-senior-admins-can-run-servers reflex of frank_m ...
Nonsense.
But everything, that is currently required, is written down in #2. As soon as he gets familiar with IP networks, he can configure his server. He will need it anyway. If not today, latest tomorrow.
Maybe they did update the installer
