hallo,
habe versucht auf meinen vServer mediawiki zu installieren.
leider kommt da bei der installation folgender fehler und ich habe kein plan was ich da nun machen muss.
[PHP]MediaWiki 1.15.1 Installation
Don't forget security updates! Keep an eye on the low-traffic release announcements mailing list.
Checking environment...
Please include all of the lines below when reporting installation problems.
PHP 5.2.0-8+etch7 installed
Found database drivers for: MySQL
PHP server API is cgi-fcgi; using ugly URLs (index.php?title=Page_Title)
Have XML / Latin1-UTF-8 conversion support.
Session save path (/var/lib/php5) appears to be valid.
PHP's memory_limit is 256M.
Couldn't find Turck MMCache, eAccelerator, APC or XCache; cannot use these for object caching.
Warning: shell_exec() has been disabled for security reasons in /var/www/web1/html/wiki/config/index.php on line 2011
GNU diff3 not found.
Found GD graphics library built-in, image thumbnailing will be enabled if you enable uploads.
Installation directory: /var/www/web1/html/wiki
Script URI path: /wiki
Installing MediaWiki with php file extensions
Environment checked. You can install MediaWiki.
Warning: exec() has been disabled for security reasons in /var/www/web1/html/wiki/config/index.php on line 2102
Warning: array_map() [function.array-map]: Argument #2 should be an array in /var/www/web1/html/wiki/config/index.php on line 2152
Warning: Invalid argument supplied for foreach() in /var/www/web1/html/wiki/config/index.php on line 2153
Warning: Invalid argument supplied for foreach() in /var/www/web1/html/wiki/config/index.php on line 2110
Generating configuration file...
Database type: MySQL
Loading class: DatabaseMysql
Attempting to connect to database server as web1...success.
Connected to mysql 5.0.32-Debian_7etch1-log; enabling MySQL 4.1/5.0 charset mode
Database usr_web1_11 exists
Creating tables...Query "CREATE UNIQUE INDEX user_name ON `user` (user_name) " failed with error code "INDEX command denied to user 'web1' localhost for table 'user' (localhost)".[/PHP]
