Hello all,
I upgraded my vserver with below commands
- Update your /etc/apt/sources.list according to the list above.
- Update your system. apt-get update
- Install apt from Jessie before upgrading your system. apt-get install apt -t jessie
- Upgrade your system. apt upgrade
- Upgrade your system and remove obsolete packages. apt dist-upgrade
- Carefully check all debconf prompts and update configuration files as needed.
But now i have problem with apache2 and upgrading froxlor
/etc/init.d/apache2 restart
[....] Restarting web server: apache2AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/sites-enabled/10_froxlor_ipandport_xx.xx.170.228.80.conf:5
And now i cannot access my webpages ![]()
Please help
