Problem E: Couldn't find package linux-headers-2.6.33.2-vs2.3.0.36.30.4-netcup
  • I think have problem in Linux vServer
    (most likely nobody created a linux-headers for that Linux-VServer kernel package)
    and when i tried to install script i get
    installing kernel headers for a 2.6.32/33 kernel should provide the required files..But as far as i learned i can't change or update kernel files for vServer. I wrote support mails however their answers quite far then to be good.
  • i tried update kernel headers
    [B]sudo apt-get install linux-headers-`uname -r`[/B]
    not works
    sudo -s
    ln -s /usr/src/linux-headers-`uname -r` /usr/src/linux
    cd /full/path/to/src/directory
    ./configure --prefix=/usr
    make
  • On my vServer, /usr/src/linux is a symlink to linux-headers-2.6.33.2-vs2.3.0.36.30.4-netcup as usual, but this directory does not exist. :o
    A lot of software need the kernels source for proper configuration. So please - netcup - provide it. Thank you!
    Roman
    vServer: Root-Server M, OS: Debian 8.2 Jessie
  • Zitat von Roman;26781
    Roman
    I wrote many times to Netcup but they didnt provide it..
  • The problem is: You can't change or controll the kernel with Linux-VServer ;)
    You can't use e.g. iptables, because the kernel is shared for all users on a node.
    Regards,
    Christian
  • My vServer here is running with 2.6.33.2-vs2.3.0.36.30.4-netcup and kernel-headers 2.6.30-r1. I customized my system completely and it runs without any problems.
    masterofdeath, why do you want the same version of the kernel headers? In production use you only need a similar version for compiling kernel-near software. If you want to build modules, you generally need the complete kernel sources and .config of the running kernel.
    Do you manage your vServer with Copy&Paste? So you won't be happy with your system.
    Just use
    and it will work.
