Ich hab Business 10G webspace und möchte für mein forum Project Honey Pot nutzen. Ich soll laut anleitung jetzt die datei favourable.php freigeben, ist dies mit webspace überhaupt möglich?
mystd -
3. August 2011 um 19:42 -
Zeig uns doch mal die Anleitung.
Ich gehe davon aus, dass du die Dateirechte höher stellen musst.
After installing your script you need to activate it. To do so, simply install the script in the appropriate place on your server and access through your website via any Internet browser. If installed correctly, the script will contain instructions and a link. By clicking on that link you will activate the script so it can begin to deliver honey pot addresses.
If the activation instructions do not appear, or you are taken to an error page, it means you have not correctly installed the script. First make certain the script is in the right place on your server and the permissions, owner, and group are set correctly so the script can execute on your server. Note that if you edited the contents or name of the script it may not activate. If you continue to experience problems, you should check with your server administrator and download a new copy of the script.STEP 1: LOCATE THE SCRIPT
Locate the copy of the script included in the downloaded file. In
your case, the script is named:
favourable.phpSTEP 2: COPY IT TO THE CORRECT LOCATION
Copy the script into your web server's html folder. On most
Unix/Linux systems this folder will be called:
htdocs/ or www/
If you do not know where your html folder is located, ask your
web server administrator. Ensure when you copy the script you do
not change its name or otherwise modify it.
You may install the script in any folder that is accessible
over the web. For example:
htdocs/folder1/folder2/STEP 3: SET THE PERMISSIONS
On most systems, in order for the script to execute its
permissions must be set correctly. On Unix/Linux systems you
can set the scripts' permissions with the following command:
chmod 644 favourable.php
STEP 4: INSTALL PHPThe script requires your webserver to run PHP. If it has not already
been installed you will need to install it.
You may download the latest version of PHP from following website:
http://www.php.net
Installation instructions can be found here:
http://www.php.net/manual/en/install.phpSTEP 5: VISIT THE SCRIPT
Once you've installed the script on your web server you need to
access it. Open a web browser and type in the URL of your web site
followed by the path to the script. For example, if you installed
your script inside 'folder1/folder2/', access the script like so:
http://www.bds-projects.com/folder1/folder2/favourable.php
If installed correctly, you will see instructions on how to
finalize the installation. -
Laut der Anleitung möglich
