Hello evryone,
I’m troubleshooting a one-way UDP/RTP issue and would appreciate some advice.
Environment
Server IP:
159.195.85.32 -
Remote IP:
35.146.30.136 -
OS: Debian 13
RTP port range:
UDP 10000–20000 -
Destination port:
UDP 4006
Issue
UDP/RTP packets from
159.195.85.32→35.146.30.136are sent successfully. -
UDP packets from
35.146.30.136→159.195.85.32do not arrive. -
This results in one-way audio.
tcpdump on 159.195.85.32
Observed output shows only outbound traffic:
No inbound UDP packets are seen from the remote side.
Checks already done
Local firewall allows UDP 10000–20000
Routing looks correct
Remote side confirms outbound UDP traffic
Issue persists even when firewall is temporarily disabled
Questions
Has anyone experienced silent UDP blocking by hosting providers?
Could anti-DDoS, rp_filter, or conntrack limits cause this behavior?
Any recommended tests to clearly prove provider-side UDP filtering?
Thanks in advance for any help.
