This has been going for like 30 minutes.
How long should i expect my server to be down?
It can take some time. What kind of server do you have?
i dont know the exact name of it. where would i find that?
its 24gb ram 960gb storage 8 cores
'some time' like 5 hours?
it's a dedicated server
A dedicated server or a root server? Nevermind. It should have stated how long it will take before you startet the process. 960GB is lots of storage. My VPS with 750GB (Optane) finished it in around 45 minutes, but of course it depends on your disk usage.
I won't say 5 hours, in my opinion not longer than 2h. Of course I can be wrong, maybe another forum member with a similar server can say something![]()
I've used 450 GB of the 960 on my root server.
If it took 45 minutes for you I guess i should expect 2-3 hours.
so far it's been an hour
You don't have a dedicated Server. I think you have a root server ![]()
